previous
Folio Tax - Style 03 (foliotax_03 with FOL1.FMX)
This report was developed to meet reporting requirements for properties located in Portugal.
The intent is to display the breakdown of VAT Tax that was posted on each reservation for a specified date range.
The report will NOT refer to the Cashiering>Reports Tax Buckets application setting. If there are net/ tax amounts in all the 20 buckets then report will include all the 1-20 tax and net buckets irrespective of what is selected in the setting. It will not include the net / tax groups for which values do not exist.
Note: To save paper the report will print only those tax groups (1 to 10) that were actually used in the requested time frame.
The report selects from the following tables/views:
FOLIO_TAX
NUMBER_SCALE (this table has one column (n) and contains all numbers from 1 to 10000)
NAME_VIEW
FOL1.FMX Selection Criteria
Date Range
From Date. Manually enter, or select the Calendar button to choose, the beginning date for the date range used in the results of the report.
To Date. Manually enter, or select the Calendar button to choose, the ending date for the date range used in the results of the report.
Sort Order. Chronological, Folio No., Room
