previous
Assign Rooms All (hkassignroomall with GENREPPAR.FMX)
The Room Conditions All Report displays all rooms that have been blocked using the reason codes under the assignment status of All, General, and Show. General Assignment will prevent the room from being displayed when you search for vacant rooms. Rooms displaying Show status will not be blocked from check-in Print this report to identify the kind of assignment and availability for all rooms.
Selection Criteria
Room Condition. A Single Multi Select LOV to filter the results by the condition of the room.
