previous
RMS Hurdle Point (hurdle_point with GEN1.FMX)
RMS Hurdle Point displays all hurdle points (rates) for a property for a date range specified. The output is based on the activation of a Revenue Management license code. The report can be used by the hotel to check the Hurdle Point by Product Class/Yield Category for up to a year out and also indicates the Sell To Capacity values that have been set for the hotel in addition to providing you with inventory information.
Selection Criteria
Date Range
From Date. Type or select the calendar button for the beginning date for the report results.
To Date. Type or select the calendar button for the ending date for the report results.
