previous
Post Installation
After installation, run the OEDS Wizard.
Note: There is a Setup.EXE that you will run for a new installation and an Upgrade.CMD that you will run for upgrades. When installing, the wizard should be given administrative rights. All other screens will remain the same.
The OEDS Wizard creates an Application Pool called "OEDS" and attaches it to all virtual directories it creates. This topic shows how to view the OEDS application pool and verify it is attached to the virtual directory.
Viewing the OEDS Application Pool
To view the OEDS application pool
  1. Go to the Server Manager by expanding the Roles>Web Server (IIS) tree.
  2. Select Internet Information Services (IIS) Manager.
  3. From the Internet Information Services (IIS) Manager screen, select Application Pools.
running_oeds_wizard_application_pool
Verifying the OEDS Application Pool
To verify the OEDS Application Pool is attached to the virtual directory, follow these steps:
  1. Right click the virtual directory and select Manage Application>Advanced Setting.
    manage_application_advanced_settings
  2. On the Advanced Settings screen, you should see "OEDS" displayed across from the Application Pool.
    server_manager_advanced_settings_screen
