previous
Transaction Statistics (restranstat with RESORS1.FMX)
The Transaction Statistics Report displays reservations (Resv no, Guest Name, Market Code, Rate Code, Travel Agent, Arrival, Room Type, Clerk, Rooms, Nights and Rate amount) and totals for Nights, Rooms, Rate Amounts by Groups . You can filter the report by Property and Date range. The report groups by Property, Source and Status.
Selection Criteria
Property.  Select the properties whose transaction activities you want to view.
Date Range
From/To Date. Enter the beginning and ending date range for the transaction statistics you want to view.
