previous
Registration Card - Schedine (schedine with RES9.fMX)
The Registration Card Report displays all registration cards and corresponding information that have been printed for a given date. This report is specific to countries located in Italy, and must therefore be manually added to the Reports Menu.
Selection Criteria
Arrival Date. Date. Manually enter, or select the Calendar button to choose, the arrival date for the report. Defaults to the current business date.
Group. Select the Group from the single select list of values.
Report Data
Note: If your property is included in a database schema that has properties in Korea (KR) country mode and you have initiated and completed the associated encryption process, the Date of Birth information is masked with Xs by default.
The following columns appear on the report:
