4. Annexure A - List of End of Cycle Functions
This chapter contains the following topics:
4.1 Mandatory Functions of EOC Cycle
This Annexure contains details of all the mandatory functions that should mandatorily run as part of the different stages of the EOC cycle.
The contents of this Annexure are organized on the basis of the module to which the function belongs.
4.1.1 Beginning of Day (BOD) Functions for all Modules
The mandatory functions for BOD are marked with a Yes under the Mandatory Column.
Module
Function
Frequency
Mandatory
SMS
Change time
Daily
Core
Posting of tank
Daily
CASA
Group Status Change
Daily
DE
Till opening
Daily
Yes
DE
Cash movement function
Daily
LD
Auto- daily
Daily
LD
Auto- initiation
Daily
LD
Auto- liquidation
Daily
MM
MM activation of forward contracts
Daily
Yes
MM
MM auto- liquidation of contracts
Daily
Yes
MM
MM auto- liquidation of interests
Daily
Yes
MM
MM auto- rollover execution
Daily
Yes
MM
MM maturity report
Daily
MM
MM exception report
Daily
Yes
BC
Accruals
Daily
Yes
BC
AutoLiq
Daily
Yes
BC
Auto-change of Acceptance to Advance
Daily
Yes
BC
Auto- status control
Daily
BC
Floating rate change
Daily
BC
Tracer generation
Daily
LC
LCEOD
Daily
Yes
SI
Sweeps
Daily
AEOD
Refinance rates
Input
AEOD
Currency rates
Input
AEOD
Forward rates
Input
AEOD
Discount rates
Input
4.1.2 End of Day (EOD) Functions for all Modules
The mandatory functions for EOD are marked with a Yes under the Mandatory Column.
Module
Function
Frequency
Mandatory
SMS
Log of events
Daily
SMS
Security violations report
Daily
Core
Financial balancing
Daily
Core
Date change
Daily
Core
Accounting entries history
Daily
Core
Currency position update
Daily
Core
Auto- revaluation
Daily
Core
Account statement
Daily
Core
Brokerage liquidation
Daily
Core
Brokerage liquidation report
Daily
Core
Limits updation
Daily
CASA
Group Status Change
Daily
CASA
Liquidating PDC Linked Schedules
Daily
DE
Daily cash movement function
Daily
Yes
DE
Daily cash movement report
Daily
Yes
DE
Batch totals report
Daily
DE
Transaction journal
Daily
Yes
DE
Daily teller transaction report
Daily
DE
Till balancing exception report
Daily
Yes
DE
Till closing position (history)
Daily
Yes
CASA
Amount block
Daily
CASA
Stop payment
Daily
FX
FX contract revaluation
Daily, Monthly
Yes
FX
FX contract auto liquidation
Daily
Yes
FX
FX auto- rollover
Daily
Yes
FX
FX settlement message generation
Daily
Yes
FX
FX fetch unauthorized
Daily
Yes
FX
FX netting of (settlements amounts)
Daily
Yes
FX
FX contracts purge
Optional
LD
Auto- daily
Daily
LD
Auto- interest liquidation
Daily
LD
Auto- liquidation
Daily
LD
Auto- rollover
Daily
MM
MM activation forward contracts
Daily
Yes
MM
Auto- liquidation of MM contracts
Daily
Yes
MM
Daily
Yes
MM
Generation of payment messages, days before actual date
Daily
Yes
MM
Daily
Yes
MM
MM interest rate revision
Daily
MM
MM fetch unauthorized
Daily
MM
MM maturity report
Daily
MM
MM daily movement
Daily
Yes
MM
MM exception report
Daily
Yes
BC
Accruals
Daily
Yes
BC
Auto- liq
Daily
Yes
BC
Auto-change of acceptance to advance
Daily
Yes
BC
Daily
LC
LCEOD
Daily
Yes
LC
LC tracer general
Daily
Yes
IC
Liquidation
Daily
IC
Interest advices
Daily
IC
Accruals
Daily
SI
SI Batch Process
Daily
Yes
GL
GL report
Daily
GL
Cash flow report
Daily
MIS
Product profitability
Daily
MIS
Customer profitability
Daily
MIS
Pool profitability
Daily
MIS
MS clause- wise report
Daily
AEOD
Change time level
Daily
4.1.3 Pre-End of Day Functions for all Modules
Module
Function
Frequency
Mandatory
BC
Daily
LC
LCEOD
Daily
Yes
IC
SI
Payments
Daily
The following is the list of pre-EOC functions that have to be executed after EOTI has been marked:
Module
Function
Frequency
Mandatory
BC
Daily
LC
LCEOD
Daily
Yes
SI
Payments
Daily
4.2 Account Revaluation Batch
As part of EOD batch programs, the system will maintain the account revaluation batch (ACCREVAL). This program will be maintained at EOTI (Pre-EOC) stage of end of day. Revaluation accounting is posted in foreign currency with equivalent of LCY difference.
This batch will do the revaluation separately for Internal GLs, Customer Account Revaluation is maintained for profit and loss GLs in the GL maintenance. For the GL’s maintained at the revaluation setup, you need to check the ‘Revaluation’ checkbox at GL chart of accounts level.
This batch will also transfer the foreign currency positions to a designated branch based on the revaluation/ position transfer setup maintained at the branch preferences level.
The system will transfer the position from the existing branch to the treasury branch. If the position is negative in the given GL, then the system will choose the offset account as Position asset GL and if the position is positive in the given GL, then the system will choose the offset account as Position liability GL.
The sequence of the EOD between the designated branch and all other branches are operationally controlled.
