Configuring Import/Export
The Import/Export allows you to import/export data in CSV format for a particular list type (Blacklist/Ratelimit/Redirect).
You can only import/export files in .csv format. Maximum file size allowed is 10 MBytes.
From this screen, you can:
Number Prefix: You can enter prefixes of the phone numbers to save the data for exporting and importing. The Blacklist information is in the international format without a leading + or leading zeros.
If you use a different numbering scheme in your network, provide the prefix to prepend to the international numbers or a regular expression to transform the numbers.
Import: Import either Blacklist, Ratelimit, or Redirect lists. You can select the required option from the drop-down list and Select file from your system and click Upload for importing the file.
Export: Export either Blacklist, Ratelimit, or Redirect lists. You can select the required option from the drop-down list and click Export for exporting the file.
