Specifying Ratelimit List
The Ratelimit allows you to add the custom entries. You can add Phone numbers, IP addresses, User names and SIP User Agents. You can also exempt users by removing them from the global ratelimit.
Customers may either upload the ratelimit information provided through the import menu or they can manually enter the custom entries.
Global flag is marked as True for entries uploaded through import menu such as the phone numbers, usernames, hostnames, and SIP User Agents which have been identified and verified to be involved in fraudulent activity.
Use the Configuration menu to adjust the points awarded for prefix and exact match hits from this list.
Should you want to exempt a specific entry, check the corresponding flag while adding or modifying that entry. But that exemption does not work for other lists like blacklist or redirect. If you want to exempt an entry from all lists, add the same in Whitelist. The CPS or MAC entries are not taken into account for raising incidents from ratelimit list, only presence is checked.
Entry can also come in this list via Automatic Configuration: Subscribed flag would be true for such entries and also those entries cannot be used for raising further incidents.
The Ratelimit supports all the data types supported by SBC for processing the calls. Following are the available data types:
from-hostname
to-hostname
from-phone-number
to-phone-number
from-username
to-username
user-agent-header
You can filter the data based on these data types. Click the required data type in the screen and data is displayed for the selected data type.
You can Add, Edit, and Delete the users. Double-click a user to edit the details.
Adding a Ratelimit User
You can add a ratelimit user and specify the data type. Fraud Monitor captures the information for the user based on the data type.
To add a ratelimit user:
From the Settings screen, click Ratelimit.
The Ratelimit screen appears.
click Add.
Add a Ratelimit User screen appears.
From the Type drop-down list select the data type for the user.
In the Match Value field, enter the value of the type selected above. The value depends on the Type.
For example, if you have selected, from-phone-number for the Type, then the Match Value must be a valid phone number.
In the Calls Per Second field, enter the number of seconds that call shall be allowed.
In the Max Active Calls field, enter the number of calls allowed for the user from the Type selected.
In the Comment field, enter any additional information for the user.
(Optional) Select User exempted from ratelimit to exempt from ratelimit.
By selecting this option, you are exempting the user from the global ratelimit. Fraud Monitor remains susceptible to accumulating points from other rules defined for the user.
Click Save to add the user or click Cancel.
Configuring Ratelimit
Configuring Ratelimit screen allow you to enable and disable the Ratelimit feature for specific data types, such as Phone numbers, IP addresses, User Names or SIP User Agents. Disabling a data type has an effect on Ratelimit List. You may assign points for both prefix and exact hits for each data type.
You have to modify Current Notification Thresholds from Notifications screen.
