Installing Fraud Monitor
To install Fraud Monitor:
Install Session Monitor using RPM. Refer to Installing Session Monitor using RPM in the Session Monitor Installation Guide.
Login to Platform Setup Application (PSA) and configure the machine as Fraud Monitor. Refer to the section, About the Platform Setup Application in Session Monitor Installation Guide.
On the Machine Type screen, select Aggregation Engine.
Select Fraud Monitor.
Follow the steps in the Installation wizard.
After successful installation, the user should be able to login to the application with Default credentials. Contact your Oracle Sales Representative.
