Status
The following status are shown for the RTP packets:
- Active streams: Specifies the number of RTP streams found. Only the traffic that matches the filter is counted.
- Packets processed: Specifies the packets that match the filter and processed successfully.
- Packets dropped: Specifies the packets that match the filter but not processed due to insufficient resources.
