Changing Your Password
To
change your password, click your user name in the top right-hand corner of the
screen and select Change Password from the drop-down menu.
In the Change Password dialog box, enter the old and the new passwords in the indicated fields and click Change.
The password contains only digits, letters and white spaces.
