Global Statistics
The following statistics are shown for all devices:
- Total sniffed: Specifies the number of packets sniffed across all configured devices.
- Total dropped: Specifies the number of packets that were not processed. Packets were dropped either by the NICs or during processing due to system performance reasons. If possible, tighten the filter rules and disable the Check all traffic for signalingfilter option in Media Protocols to ignore unnecessary packets and reduce stress on the system. If that is not possible, consider upgrading the machine.
