About the Platform Setup Application
The Platform Setup Application guides you through the Session Monitor configuration steps, including configuring the machine type, capture settings, and simple mail transfer protocol (SMTP) settings as follows:
- Accept the license agreement to proceed with the Platform Setup Application.
- The menu on the right shows your progress during configuration.
- The Machine Type page sets which licensed Session Monitor applications are installed. In the Server Certificate page, you can upload your signed certificate for secure HTTPS connections.
- Subsequent sections
configure the Session Monitor server for your network. These steps are
optional.
Except for Machine Type and Extensions, you can review and change settings at any time by visiting the Platform Setup Application at https:// ip_address /setup/, where ip_address is the IP address of the server that hosts a Session Monitor application. This URL is valid for any Session Monitor server.
- In the final step, each selected Session Monitor application is installed.
After a successful installation, the log in page appears for each of your licensed Session Monitor application.
