Installing Software Update
After you log in to the product interface, you can see the status of the system or update the system. A system update will update all applications as well as the Platform Setup Application itself.
The Software Version page shows the currently installed components and the software version.
To install a software update, go to the Software Version page and select the update file (file type .rpm) that was provided by Oracle or your service provider. Click Apply to initiate the upload.
When the upload has finished, the page will show the version number and issue the date of the update. Click Install to proceed with upgrading the system. You can also abort the upgrade by clicking Clear.
Important:
Session Monitor or parts of it may not be available during the update process.Platform Setup Application will show the progress during the upgrade. You may click Close to hide the progress window.
source /opt/oracle/ocsm/ocsm_env.sh
If you have a setup with multiple servers (for example, ME, MEC, Probe(s) and OCFM), upgrade all of them at the same time. Running different servers (ME, MEC, probe(s), OCFM) of the Session Monitor on different versions is not supported.
