Session Monitor Supported Hardware
Session Monitor is supported on Oracle, Sun, and HP systems.
Following table lists the hardware supported for Oracle systems.
Table 1-3 Supported Hardware for Oracle systems
| Component | Requirement |
| Server | The following severs are supported:
| Network Adapter | The following adapters are supported:
Oracle X7-2 server supports only Session Monitor Installation using RPM installer.The following table lists the hardware supported for Oracle systems.
Table 1-4 Supported Hardware for Oracle Sun systems
| Network Adapter | The following network adapters are supported:
The following table lists the hardware supported for HP systems.
Table 1-5 Supported Hardware for HP Systems
| Server | The following servers are supported:
| Network Adapter | The following network adapter s are supported:
| Driver/Chipsets | The following drivers/chipsets are supported:
