Session Monitor Operating System Requirements
The following table lists the supported operating systems for running Session Monitor.
Table 1-1 Supported Operating Systems
| Product | Version | Notes |
| Oracle Linux 7 x86-64 (64 bit) | 7 or higher (with Oracle UE Kernel for Linux) | By default Oracle Linux installs Kernel 3.
Oracle recommends that the latest Unbreakable Enterprise (UE) Kernel 4 for Linux is installed. |
- You must configure network device when installing Oracle Linux 7.
- If required, update the DPDK Drivers.
- The ISO installer ships with the latest Oracle Unbreakable Enterprise Kernel for Linux.
