Report Contents
The contents of a report include:
- Information on the available hardware of the machine that the monitoring solution is running on
- Log files
- Configuration of the monitoring solution
- Statistics about the performance and status of components of the system and of the monitoring solution
- If the check box Include mysql dump... is checked, the report includes a dump of most of the database tables. Note that the respective tables might be huge.
- If the check box Include mysql dump... is not checked, the report will include only minimal information about the database tables.
Sensitive information is removed before report creation, including, but not limited to, passwords, keys, and certificates.
