Password Settings for User Account
You can
define the password settings for users using Mediation Engine Connector
settings.
To modify the password settings:
- Login to Mediation Engine Connector as an admin.
Click
Admin and select
Settings.
The Settings screen appears.
- From the Settings menu, click Password Settings.
To enforce users to change their password regularly, set the time
period by doing the following:
- Select Force users to change their password regularly.
- Enter the number of days in the Period in days to force password change for users with access to sensitive data field. The default setting is 90 days.
- Enter the number of days in the Period in days to force password change for users without access to sensitive data field. The default setting is 180 days.
- Click Save to save the changes or click Cancel.
The entries in these fields are applied when the user changes the password next time. -
Enforce stringent password rules by doing the following:
Select
Enforce stringent password rules to increase the level of
security required in user passwords.
A stringent password:- Should not begin with a digit
- Must contain at least one uppercase letter
- Must contain at least one lower case letter
- Must contain at least one digit
- Must contain a special character such as @, #, $, -, _
- Must be different from the previous password
By default, the account gets locked after three unsuccessful attempts for 15 minutes.
- Click Save.
Select
