Understanding Mediation Engine Connection Testing Error Codes
The
following table describes some common error codes that appear in the connection
testing of Mediation Engines.
Table 3-1 Mediation Engine Connection Testing Error Codes
| Error Code | Brief Description | Error Description | Possible Required Actions |
| 401 | Unauthorized | A misconfiguration in the Node Secret or the Masterweb Secret. | Ensure that Secrets are correctly setup both in Mediation Engine Connector and Mediation Engine and that the same product versions are used for Mediation Engine and Mediation Engine Connector. |
| 408 | Timeout | A timeout occurs when trying to connect to the Mediation Engines. | Contact your System Administrator. |
| 500 | Internal Server Error | An unknown connection error occurs in the Node. | Contact your System Administrator. |
Any other error code that appears is attributable to the local network connection error issues. Check the network connections and contact your System Administrator or Network Administrator for assistance.
