Adding a Group Tab
To add a group tab:
  1. Click Add group tab beside the Dashboard tab.
    A New Group 1 tab is created.
  2. Double click the New Group 1 tab and rename the panel group. You can create multiple dashboard panels.
When a new widget is added in the Dashboard tab which is not the default, the widget gets added in the default dashboard.
