Disconnecting Mediation Engine from Mediation Engine Connector
To
disconnect Mediation Engine from Mediation Engine Connector:
The
Mediation Engine is disconnected from Mediation Engine Connector.
Though, Mediation Engine disconnected from Mediation Engine Connector, Mediation Engine details appears in the mediation engine list. To remove the Mediation Engine from the list, navigate to ME Management, select the node, click Delete Selected and the click Save. If you click Replicate Configuration, the mediation engine will connect back to the Mediation engine connector. Make sure to note down all the fields of this entry before disconnecting for future reference.
