Permission Settings for Accessing ISR Recordings
A user must be given permissions to be able to configure ISR access and listen to the ISR audio call recordings.
To give permissions to an user:
- From Settings page, under User Management, select an existing user and click Add rights. - The User Information screen appears.
- Click Next. - The Permission for Modules screen appears.
- Click Next. - The Permission for Settings screen appears.
- Select the ISR Recording check box.
- Click Next. - The Summary screen appears.
- Click Finish.
The user can now enable the ISR access and listen to the ISR recordings. See "ISR".
