Examples
The following examples describe how to create an algorithm using the test references.
Match by the Caller and the Callee
The following algorithm matches two call legs if:
The last 6 characters of caller are equal, as found in either the From header or in the P-Asserted-Identity,
And the last 6 characters of the callee are equal, as found in either the To header or in the Request-URI.
(cond
    ((uri_user 6 ("from" "pai"))
        (uri_user 6 ("to" "ruri"))
The following example modifies the one above to return true, if either the caller or the callee matches:
(cond
    ((uri_user 6 ("from" "pai")) #t)
    ((uri_user 6 ("to" "ruri")) #t)
Match by Generic Algorithm
The following algorithm is an example of a generic algorithm, which should give good results for a wide range of SIP devices.
(cond
    ((call_id 0) #t)
    ((sdp_media_ip_port) #t)
    ; custom header
    ((hf_equals "session-id") #t)
    ((time_diff 15000 2000) #f)
    ; Matching by from and to
    ((uri_user 6 ("from" "pai" "rpid" "ppid"))
        (cond
            ((uri_user 6 ("to" "ruri" "diversion")) #t)
            (#t #f)
    ; nothing matched, return false
    (#t #f)
The above algorithm:
Checks first the Call-ID. If the two call legs have the same Call-ID header, then it returns true.
Checks the SDP bodies. If the two call legs have the same media IP and port number, or if the session ID are equal, then it returns true.
Checks if the custom Session-ID header is present in both call legs, and if their values are equal, then it returns true.
Checks if the start time stamps of the two call legs are too far one from each other, and if so, returns false.
Checks if both the caller and the callee match, by comparing the URIs from several headers. If a match is found for both of them, it returns true.
If none of the above is true, it returns false.
