SSL Implementation
For all HTTPS connections (ME-MEC, ME-FDP, ME-ISR, ME-Probe) it is ensured that a proper SSL certificate validation done.
There is also an option on Trusted Certificates page, if hostname should be validated.
On the Trusted Certificate page, enable the Skip hostname validation for HTTPS connection checkbox when uploading the certificates that does not contain valid hostnames.
