Installing Session Monitor Securely
Perform a custom installation to avoid installing options and products you do not need. If you perform a typical installation, remove or disable features that you do not need after the installation.
When installing Session Monitor, do the following:
Change the password when prompted.
On the Network Settings page, enable monitoring only on necessary interfaces.
On the SMTP Page:
If your SMTP server supports TLS, make sure to enable TLS.
If your SMTP server supports authentication, make sure to enable authentication and to use an account dedicated to Session Monitor.
On the Date & Time page, (if your organization runs an NTP server) make sure to provide the IP address of the local and redundant NTP servers.
