IPv4/IPv6 Dual Stack
While major carriers are proceeding toward a pure IPv6 network for next generation services, current practicalities require the continued support of IPv4 handsets and other devices. As a result, the Oracle Communications Subscriber-Aware Load Balancer provides support for single non-channelized physical interfaces that support both IPv4 and IPv6 ingress and egress on the same network interface.
Support for the dual stack interface requires no new additional configuration elements, and is provided by the proper configuration of the following elements in the ACLI Configuration Guide:
| Configuration Element | Section containing configuration element in the ACLI Configuration Guide documentation |
| Physical Interfaces | (Platform) Physical Interfaces: OCSLB in the System Configuration chapter. |
| IPv4 Network Interfaces | IPv4 Address Configuration in the System Configuration chapter. |
| IPv6 Network Interfaces | Configuring Network Interfaces: OCSLB, Licensing, Globally Enabling IPv6, IPv6 Address Configuration, IPv6 Default Gateway, and Network Interfaces and IPv6 in the System Configuration chapter. 0) |
| IPv4 & IPv6 SIP Interfaces | SIP Interfaces in the SIP Signaling Services chapter. |
| IPv4 & IPv6 Realms | Realm Configuration in the Realms and Nested Realms chapter. |
