Image Files and Boot Files
For Virtual Machines
The OCSLB S-CZ8.1.0M1 version includes distributions suited for deployment over hypervisors. Download packages contain virtual machine templates for a range of virtual architectures. Use the following distributions to deploy the OCSLB as a virtual machine:nnSCZ810m1-img-vm_ovm.ova—Open Virtualization Archive (.ova) distribution of the OCSLB VNF for Oracle (XEN) virtual machines.nnSCZ810m1-img-vm_kvm.tgz—Compressed image file including OCSLB VNF for KVM virtual machines.nnSCZ810m1-img-vm_vmware.ova—Open Virtualization Archive (.ova) distribution of the OCSLB VNF for ESXi virtual machines.
The Oracle (XEN) Virtual Machine, KVM, and ESXi packages include:
- Product software—Bootable image of the product allowing startup and operation as a virtual machine. This disk image is in either the vmdk or qcow2 format.
usbc.ovf—XML descriptor information containing metadata for the overall package, including identification, and default virtual machine resource requirements. The .ovf file format is specific to the supported hypervisor.legal.txt—Licensing information, including the Oracle End-User license agreement (EULA) terms covering the use of this software, and third-party license notifications.- Alternate Bootloader file:
EFI/BOOT/BOOTX64.EFI—New installations and upgrades on COTS platforms that support 64-bit Unified Extensive Firmware Interface (UEFI) mode. UEFI systems locate this file, provided in the Oracle distribution, when applicable.
