PreviousNextJavaScript must be enabled to correctly display this content
Upgrade Information
This section provides key information about upgrading to
this software version.
Supported Upgrade
Paths
Prior versions of the OCSLB were only supported on
physical platforms. This version of the OCSLB is supported only on virtual
platforms. As a result, there are no supported upgrade paths.
