| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to remove a UIM threshold from the database using the dlt-uim-acthresh command. The dlt-uim-acthresh command has only one parameter, uimn, which specifies the UIM number of the UIM threshold that is being removed from the database.
The UIM threshold must be in the database.
The example in this procedure removes the UIM threshold for UIM 1216 from the database.
Figure 4-18 Removing a UIM Threshold
