| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to remove a user from the EAGLE using the dlt-user command. This procedure can only be performed if you have been assigned the command class “Security Administration.” If the user ID does not exist in the database, the user’s characteristics cannot be changed.
rtrv-secu-user command. This is an example of the possible output.
rlghncxa03w 09-03-01 08:33:48 GMT EAGLE5 40.1.0
USER ID AGE PAGE UOUT REV LINK SA SYS PU DB DBG
frodo 0 60 * 90 * NO YES NO YES NO YES YES
DB1 U02 U03 U04 U05 U06 U07 U08 U09 U10 U11 U12 U13 U14 U15 U16
YES NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO
U17 U18 U19 U20 U21 U22 U23 U24 U25 U26 U27 U28 U29 U30 U31 U32
NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO NO
manny 36 60 60 NO YES YES YES YES YES YES
U01 U02 U03 U04 U05 U06 U07 U08 U09 U10 U11 U12 U13 U14 U15 U16
NO NO NO NO YES YES YES YES YES YES YES YES YES YES YES YES
YES YES YES YES YES YES YES YES YES YES YES NO NO NO NO YES
fred 750 0 0 NO YES YES YES YES YES YES
YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES NO
YES YES YES YES YES YES YES YES YES YES YES YES YES NO NO NO
travist 101 60 * 90 * NO YES NO YES NO NO YES
YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES YES
YES YES YES YES YES YES NO NO NO NO YES YES YES YES YES NO
dlt-user command. The dlt-user command has only one parameter, uid, which is the user ID that you wish to remove from the database. For this example, enter this command.
dlt-user:uid=travist
When this command has successfully completed, this message should appear.
rlghncxa03w 06-10-01 09:12:36 GMT EAGLE5 36.0.0 DLT-USER: MASP A - COMPLTD
rtrv-secu-user command and specifying the user ID used in step 2 with the uid parameter. For this example, enter this command.
rtrv-secu-user:uid=travist
If the user ID was removed in step 2, error message E2199 is displayed.
E2199 Cmd Rej: The specified user identification is not defined
chg-db:action=backup:dest=fixed command. These messages should appear, the active Maintenance and Administration Subsystem Processor (MASP) appears first.
BACKUP (FIXED) : MASP A - Backup starts on active MASP. BACKUP (FIXED) : MASP A - Backup on active MASP to fixed disk complete. BACKUP (FIXED) : MASP A - Backup starts on standby MASP. BACKUP (FIXED) : MASP A - Backup on standby MASP to fixed disk complete.
Figure 4-7 Removing a User from the System
