Go to primary content
Oracle® Communications EAGLE Database Administration - System Management User's Guide
Release 46.8
F11885 Revision 1
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
SLIC 32-bit to 64-bit Conversion
The following procedure is used to convert the 32-bit mode to 64-bit. The target card should already be running on the BLSLC32 GPL. Skip this procedure if the card is already running the BLSLC64 GPL.
  1. Inhibit the target card with the inh-card:loc=<card_loc>:force=yes.
    The card will boot and return to state OOS-MT-DSBLD within 60 seconds.
  2. Flash the card with the init-flash:loc=<card_loc>:code=appr:gpl=BLSLC64 command.
    After the flashing operations complete, the card will boot and return to state OOS-MT-DSBLD.
  3. Activate the new BLSLC64 GPL with the act-flash:loc=<card_loc> command.
    The card will now run on 64-bit mode and will accept 64-bit mode applications from the OAM.
  4. Update/verify the SLIC bootloader using the init-flash:loc=<card_loc>:mode=rplcebl:bits=64 command.
    If the card was already running with the desired bootloader, the command has no effect; otherwise, the bootloader will be updated.
