| Oracle® Communications EAGLE Database Administration - System Management User's Guide Release 46.8 F11885 Revision 1 |
![]() Previous |
![]() Next |
This procedure is used to change the user ID and password requirements for the EAGLE using the chg-secu-dflt command. The chg-secu-dflt command uses these parameters.
:page – The amount of time, in days, that the specified user’s password can be used before the user must change their password. The value of this parameter applies to all EAGLE user IDs unless a different value is specified for a specific user ID with the ent-user or chg-user command.
:uout – The number of consecutive days that a user ID can remain active in the EAGLE and not be used. When the user ID has not been used for the number of days specified by the uout parameter, that user ID is no longer valid and the EAGLE rejects any attempt to log into the EAGLE with that user ID. The value of this parameter applies to all user IDs in the EAGLE unless a different value is specified for a specific user ID with the ent-user or chg-user command.
:multlog – are the user IDs allowed to log on to more than one terminal at any given time.
:minlen – the minimum length of the password
:alpha – the minimum number of alpha characters (a - z)
:num – the minimum number of numeric characters (0 - 9)
:punc – the minimum number of punctuation characters (any printable character that is not an alphabetic character, a numeric character, the space bar)
:minintrvl – the minimum number of days before a password can be changed again.
:pchreuse – the number of characters that cannot be reused from the current password when setting the new password. For example, if the pchreuse parameter value is 5, no more than five characters of the current password can be reused in the new password.
:pgrace – the number of days after password expiration during which the user can login without changing their password.
:pnotify – the number of days before password expiration that the user is notified about the expiration.
:preuse – the number of previous passwords that cannot be used. If the preuse parameter value is 6, the previous six passwords cannot be used.
The chg-secu-dflt command also contains the wrnln,wrntx, and clrwrntx parameters. These parameters are used to configure the unauthorized use warning message that is displayed when a user logs into the EAGLE. To configure the unauthorized use warning message, go to the Configuring the Unauthorized Use Warning Message procedure.
Even though the minlen parameter specifies the minimum length of a password, the password must also contain the minimum number characters defined by the alpha, num, and punc parameters.
The examples in this procedure are used to change the security defaults to these values.
page = 100 days
uout = 50 days
multlog = yes, to allow the user IDs in the EAGLE to log onto more than one terminal at any given time.
minlen = 12 characters
alpha = 2 characters
num = 2 characters
punc = 2 characters
minintrvl = 5 days
pnotify = 14 days
pgrace = 2 days
preuse = 6 passwords
pchreuse = 5 characters
When the EAGLE is delivered to the user, the database will contain these security default values.:page = 90 days
:uout = 90 days
:multlog = no
:minlen = 8 characters
:alpha = 1 character
:num = 1 character
:punc = 1 character
:minintrvl = 1 day
:pnotify = 7 days
:pgrace = 3 days
:preuse = 5 passwords
:pchreuse = 4 characters
The rtrv-secu-dflt command uses the msg parameter to specify whether the unauthorized use warning message text is displayed in the command output. The msg parameter has two values.
yes – the unauthorized use warning message text is displayed.
no – the unauthorized use warning message text is not displayed.
The default value for this parameter is no.
Regardless of the value specified for the msg parameter, the user ID and password security defaults are displayed in the rtrv-secu-dflt command output.
Figure 4-2 Changing the Security Defaults
