11. Launching Application
Verifying Successful Application Deployment and Launching Application
Successful Application deployment can be verified by following:
- Making sure that the state is ACTIVE and health is OK in the Weblogic.
- Access and log into the application.
After you enable SSL you can launch the application via https:\\ protocol.
To launch application
- Verify if the deployed OFSLL application is ‘Active’.
- The URL of the OFSLL application will be of the format - https://<hostname>:<Port>/<ContextName>/faces/pages/OfsllSignIn.jsf (Example: https://localhost:7003/ofsll/faces/pages/OfsllSignIn.jsf)
- Login with the user credentials that was created in Users Creation.
- After successful login, the following screen is displayed
