Go to primary content
Oracle® Communications Diameter Signaling Router Diameter User's Guide
Release 8.4
F12290
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Adding Peer Node Groups
Use this task to create new Peer Node Groups.
  1. Click Diameter > Configuration > Peer Node Groups.
  2. Click Insert.
  3. Enter a unique name for the Peer Node Group Name in the Peer Node Group Name field.
  4. Select a Peer Node Name from the Peer Node Name list.
    To add another Peer Node Name, click Add and select a Peer Node Name in the new text box.
  5. Click OK, Apply, or Cancel.
    The following conditions exist:
    • You can only specify Peer Nodes whose Dynamic attribute is NO to be selected for inclusion in a Peer Node Group.
    • Peer Nodes created by the Dynamic Peer Discovery feature cannot be included by any Peer Node Group instance.
    • If you attempt to insert or update a Peer Node Group instance and the specified Peer Node whose Dynamic attribute value is YES.
    • Peer Route Groups are always statically configured; no statically configured instance can refer to a dependent GUI element that was added to the configuration as a result of Dynamic Peer Discovery.
