Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.4
F12292
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Adding a server to a server group
Only after a server group is created can servers can be added. Use this procedure to add a server to a server group:
  1. From the main menu select Configuration > Server Groups.
  2. From the table, click to select the server group you want to edit.
  3. Click Edit.
    The Servers Groups [Edit] screen displays the servers in the network element that are possible candidates for inclusion in the server group.
  4. To add a server to the server group, select the checkbox for SG Inclusion. When checked, the server is included in the server group.
  5. Click OK to submit the information and return to the Server Groups screen, or click Apply to submit the information and continue adding additional data. Clicking Cancel discards all changes and returns return you to the Server Groups screen.
