Identifying the Diameter network and properties for Online Charging DRA
- Identify and log the hardware profile type for each of the DA-MP Servers (PCA).
- Identify and log the number of Online Charging clients (CTFs) and Online Charging servers (OCSs) in the network.
- Identify and log the diameter attributes for all the Online Charging clients and Online Charging servers in the network - FQDN, Realm, IP address.
- Identify and log the type of diameter Transport Protocol needed for all the Online Charging clients and Online Charging servers - TCP/SCTP..
- Identify and log the type of diameter connection mode needed for all the Online Charging clients and Online Charging servers - Responder/Initiator/Responder-Initiator.
- Identify and log the Peer Node Identification for all the Online Charging clients and Online Charging servers - IP Address/FQDN.
- Identify and log the route groups and route lists needed for Online Charging servers.
- Identify and log the number of peer route tables and peer route rules needed for the diameter configuration for Online Charging servers
- Identify and log the number of Application Route Table entries and for OC-DRA message processing.
- Identify and log the TSA used for local nodes if IPFE is used.
