Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.4
F12292
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Editing CTFs
Use this task to edit CTFs.
  1. On the Active SOAM, click Policy and Charging > Configuration > Online Charging DRA > CTFs.
    The screen displays a list of the configured CTF Peer Nodes that are used when a new subscriber binding is created.
  2. Click in the Comments field of the row to select the CTF to edit.
  3. Edit the Comments field for the selected CTF.
    The CTF Peer Node name cannot be changed.
  4. Click:
    • OK to save the change and return to the Policy and Charging > Configuration > Online Charging DRA > CTFs screen.
    • Apply to save the change and remain on this screen.
    • Cancel to return to the Policy and Charging > Configuration > Online Charging DRA > CTFs screen without saving any changes.
    If Apply or OK is clicked and the selected CTF Peer Node Name entry no longer exists (was deleted by another user), an error message appears.
