On the Active SOAM, click
The screen displays a list of PCRF Pools or
Sub-Pools configured at the NOAMP.
Select a row to edit (click in the row, but do not
click on a specific element within the row).
DO NOT click the blue PCRF Pool Name or the Peer
Route Table Name (except to view the PCRF Pools (Filtered) screen or the Peer
Routes Table (Filtered) screen. The blue color indicates a hyper-link. The PCRF
Pool Name hyper-link opens the
screen and the Peer Route Table hyper-link
opens the
screen.
If the PCRF Pool has NOT been assigned a Peer Route
Table record, Not Selected is displayed in red in the
Peer Route Table Name column.
This helps to inform the SOAM user that the PCRF Pool should be mapped to a
Peer Route Table.
(optional) Click
Pause updates to suppress the
automatic screen refresh function. The default is Unchecked.
Pause updating applies to all rows on the screen.
If you add a new PCRF Pool at the NOAMP, a new row automatically appears on the
SOAM PCRF Pool to PRT Mapping screen the next time an update occurs.
Click
Edit.
The
Peer Route Table Name dropdown
menu initially displays the Peer Route Table from the row being edited and
contains all configured Peer Route Tables and Not Selected. Not Selected
provides backwards compatibility for users who had the
Site Options Peer Route Table Name set to Not
Selected. When Not Selected is chosen, PCA does not instruct DRL to use an
application specified PRT, but enables DRL use its normal PRT precedence for
PRT selection instead. If
Edit is clicked and the PCRF
Pool Name of the selected row has been deleted, an error is displayed and this
row is no longer displayed. If
Pool Name of the selected row still exists (has not been retired), the PCRF
Pool To PRT Mapping [Edit] screen is displayed with data populated from the
selected row.
Select an item from the
menu. The default is Not Selected, and the range is All Peer Route Tables
configured at this site.
Click:
- OK to save
the selection and return to the
screen.
- Apply to
save the selection and remain on this screen.
- Cancel to
return to the
screen without saving any changes.
Additionally, multiples issues can occur as a
result of clicking
OK or
Apply:
- If the selected PCRF Pool Name or the Peer Route
Table Name entry no longer exists (it was deleted by another user from the
NOAMP), an error message is displayed on the PCRF Pool To PRT Mapping [Edit]
screen and no changes are made to the database.
- If all the data syntax validation as per each
field's description does not meet requirements, an error message is displayed.
- If the PRT selection has changed from a PRT name
to Not Selected and the corresponding PCRF Pool is mapped to an APN, a
confirmation message is displayed with the text: PCRF Pool <PCRF Pool
Name> is currently used for bindings originating from at least one APN.
Changing the PRT entry to Not Selected may cause these bindings to fail if
originated at this site. Click Ok to continue or Cancel to return to the PCRF
Pool To PRT Mapping screen.
to Not Selected and the corresponding PCRF Pool is specified as the PCRF
Sub-Pool in a PCRF Sub-Pool Selection Rule, a confirmation dialog is displayed
with the text: PCRF Pool <PCRF Sub-Pool Name> is currently used for
bindings that match PCRF Sub-Pool Selection Rule <PCRF Sub-Pool Selection
Rule Name>. Changing the PRT entry to Not Selected may cause these bindings
to fail if originated at this site. Click Ok to continue or Cancel to return to
the PCRF Pool To PRT Mapping screen.
