Go to primary content
Oracle® Communications Diameter Signaling Router Policy and Charging Application
Release 8.4
F12292
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Editing a Resource Domain
Use this procedure to edit resource domain information
  1. Click Configuration > Resource Domains.
  2. Select the resource domain from the listing.
  3. Click Edit at the bottom of the table.
  4. Modify one or more of the resource domain information fields.
  5. Click OK to submit the information and return to the Resource Domains Configuration screen, or click Apply to submit the information and continue editing additional data.
The resource domain information is updated in the network database and the changes take effect immediately.
