Transitions Element
The <Transitions> element indicates whether the system should automatically update the activity effective date to the current system date..
Transitions Elements/Attributes
Element/Tag Attribute Definition Element/Attribute Value and Description
<Transitions >
Optional element:
Dynamically controls transaction status change/process behavior.
<Queue/>
Required element:
This element specifies how to control the activity processing behavior.
METHOD
Required attribute:
This attribute tells the system that the activity transition behavior is being changed due to the exsitence of prior activities in NUV Pending status.
'VALUATION' literal value only.
ADVANCETOSYSTEMDATE
Optional attribute
Allows the activity effective date to be changed systematically.
String:  'Yes' or 'No', or a Field or Math Variable with a value of 'Yes' or 'No'.
The default value is No.
XML Example
<Transitions>
<Queue METHOD="VALUATION" ADVANCETOSYSTEMDATE="No"/>
</Transitions>
