1. Preface
1.1 Introduction
This document is designed to help acquaint you with the integration of Oracle Banking Corporate Lending and Oracle Banking Payments in a co-deployed set up.
Besides this user manual, while maintaining the interface related details, you can invoke the context sensitive help available for each field. This help describes the purpose of each field within a screen. You can obtain this information by placing the cursor on the relevant field and pressing the <F1> key on the keyboard.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
Implementation Partners
Provide customization, configuration and implementa­tion services
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized into the following chapters:
Chapter
Description
Chapter 1
Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
This chapter helps you co-deploy Oracle Banking Corporate Lending and Oracle Banking Payments product in a single instance.
Chapter 3
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Acronyms and Abbreviations
Abbreviation
Description
API
Application Programming Interface
FCUBS
Oracle FLEXCUBE Universal Banking
OBCL
OL
Oracle Lending
ROFC
Rest of Oracle FLEXCUBE
System
Unless and otherwise specified, it shall always refer to Oracle FLEX­CUBE Universal Banking Solutions system
WSDL
Web Services Description Language
1.6 Glossary of Icons
This user manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
