1. Preface
1.1 Introduction
A limit is reviewed when it is about to expire or has to be renewed. This manual is designed to help you maintain and process Limit Review in Oracle FLEXCUBE. It also assists you in handling all the necessary activities in the life cycle of limit review process.
1.2 Audience
This manual is intended for the following Users/User Roles:
Role
Function
Back office data entry clerk
Input functions for funds
Back office managers/officers
Authorization functions
Product Managers
Product definition and authorization
End of day operators
Processing during end of day/ beginning of day
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Acronyms and Abbreviations
The following are some of the acronyms and abbreviations you are likely to find in the manual:
FCUBS
Oracle FLEXCUBE Universal Banking Solution
ELCM
Enterprise Limits and Collateral Management
CAM
Credit Appraisal Management
OBIEE
Oracle Business Intelligence Enterprise Edition
System
Oracle FLEXCUBE system (unless otherwise specified).
RM
Relationship Manager
1.5 Organization
This manual is organized as follows:
Chapter 1
Preface gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
Reviewing Limits describes about the stages in a limit review process.
Chapter 3
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.6 Related Documents
1.7 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
