The Documents Maintenance screen allow for paperless storage of documents within Oracle Financial Services Lending and Leasing system. Initially with the applications during the Lease origination cycle and later with accounts during customer service.
This chapter explains how to use the Application Document screen to:
It also explains how to use the Account Document Tracking screen to attach documents to accounts and then view these documents in a browser.
The Application Document screen consists of “Document Maintenance” and “Document Details” sections.
Credit applications are often sent or faxed to financial institutions from producers (or ‘dealers’) on behalf of the customer. These credit applications, if received as fax, can be stored in the system as images. Frequently, more than one application is received in a single fax or a single application is received across multiple faxes. In such cases, the Application Document Tracking screen can help you organize and maintain your image collection.
The Application Document screen’s Document Maintenance screen allows you to upload documents to an application in the form of GIF files, PDF files, DOC files, XLS files, and TXT files. The Document Maintenance screen’s Document Details section allows you to view these documents.
Oracle Financial Services Lending and Leasing supports the online attachment of document images to an application using the Application Documents screen’s Document Maintenance section. You can attach the documents from either a client machine or server. A default image directory can be maintained in the system using the system parameter: UIX_DEFAULT_IMAGE_PATH.
When you choose List File in the Select Document sub section in the Document Maintenance section, the system displays all available files in the selected directory in the Document Details section. You can use the Document Maintenance sub-section and Action sub-section to attach selected documents to a particular account.
To attach a document to an Application from a server
You can click Reset Path at any time to return to the default image directory.
Field: |
Do this: |
File Name |
View the file name for the document. |
Document Type |
Select the type for the document. |
Document Sub Type |
Select the sub type for the document. |
Application # |
Select the application number to attach/copy/move the document image. |
Attach |
Attach the document. |
Status |
View the status of the document. |
Tracking # |
Specify the tracking number of the document. |
Docket # |
Specify the docket number of the document. |
Location |
Specify the location of the document. |
Received Dt |
View the document image received date. |
Effective Dt |
Specify the effective date of the document. |
Expiry Dt |
Specify the expiration date of the document. |
Comment |
Specify any comments regarding the document. |
You can view the document in a browser by clicking View Document in the Document Details section.
To attach a document to an application from a client machine
Field: |
Do this: |
File Name |
Document Type |
Document Sub Type |
Application # |
Status |
Comment |
Tracking # |
Docket # |
Location |
Received Dt |
Specify the received date of the document. |
Effective Dt |
Expiry Dt |
Comments |
You can view the document in a browser by choosing View Document in the Action section.
The Action section’s Copy Document command copies the document image from one application to another application. This command has no impact on the source application or the source application’s document image.
To copy a document to an application from another application
The Action section’s Move Document command moves an existing document image from one application to another application. This command detaches the document image from the source application and attach to second application.
To move a document to an application from another application
You can view the documents attached to a particular account by loading the application on the Customer Service screen, then clicking the Customer Service tab and then clicking on the Document Tracking sub tab.
To view a document attached to an application
Field: |
Do this: |
Document Type |
View the document type. |
Comment |
Specify any comments regarding the image. |
Field: |
View this: |
Document Sub Type |
The document sub type. |
Version |
The version number. (version numbers will be incremental by batch job, first version will start with 1.0). |
Page # |
The page number. |
Document File Type |
The document file type. |
Status |
The status. |
Tracking # |
The tracking number of the image. |
Docket # |
The docket number of the image. |
Location |
The location of the of the image. |
Received Dt |
The effective date of the image. |
Effective Dt |
Expiry Dt |
The expiration date of the image. |
Comment |
Any comments regarding the image. |
-or-
You can view the documents attached to a particular application by loading the application on the Underwriting/Funding screen and then clicking on Document tab.
To locate an account document
The Account Document screen appears.
Information about the documents attached to the Application appears in the Application Documents and Application Document Details sections.
To view a document attached to an account
Field: |
Do this: |
Document Type |
Comment |
Field: |
View this: |
Document Sub Type |
Version |
The version number (version numbers will be incremental by batch job, first version will start with 1.0). |
Page # |
The page number. |
Status |
The status. |
Tracking # |
Docket # |
Location |
Received Dt |
Effective Dt |
Expiry Dt |
Comment |
-or-
The system opens a browser to display the actual document (which browser appears depends on what type of document you selected and what browsers are set up to work in conjunction with your system).
