Add Multiple VLANs
To add additional network interfaces, go to the Networks configuration page and use the Service multi-instance configuration object. When you click Add, the system displays the Network settings page with the parameters necessary to configure a network. See "Configure a Network Interface" for instructions.
Note the following guidelines for adding VLANs:
- All VLANs use the S0P0 physical interface.
- Each VLAN must correspond to one, unique SIP interface
- The network Realm identifier, VLAN ID, and network IP address cannot repeat across networks
