Automatically Upload Updated CSV Configuration Files
When you want to automatically update selected configuration objects on the OECB, you can enable the system to periodically check for updates and automatically upload the CSV configuration file. In the CSV file, you can specify the operation that you want the OECB to perform upon upload, such as add, modify, and delete data. The supported configuration objects include Agents, Dial Plan, Users, and Routing.
When enabled, the OECB checks /code/csv every two minutes for a new file and uploads it to the OECB.
See "Automatically Upload Updated CSV Configuration Files" and "Configure Automatic CSV Configuration File Upload" in the User Guide.
