Configuration Examples
This section shows you several configuration examples for HMR. This section shows the configuration for the various rules that the Oracle Enterprise Communications Brokerapplied, and sample results of the manipulation. These examples present configurations as an entire list of fields and settings for each ruleset, nested header rules and nested element rules. If a field does not have any operation within the set, the field is shown with the setting at the default or blank.
Example 1 Removing Headers
For this manipulation rule, the Oracle Enterprise Communications Broker removes the Custom header if it matches the pattern rule. It stores the defined pattern rule for the goodBye header. Finally, it removes the goodBye header if the pattern rule from above is a match.
This is a sample of the configuration:
sip-manipulation name removeHeader header-rule name removeCustom header-name Custom action delete comparison-type boolean match-value ^This is my.* msg-type request new-value methods INVITE header-rule name goodByeHeader header-name Goodbye action store comparison-type boolean match-value ^Remove (.+) msg-type request new-value methods INVITE header-rule name goodBye action delete comparison-type pattern-rule match-value $goodByeHeader msg-type request new-value methods INVITE
This is a sample of the result:
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK0g639r10fgc0aakk26s1.1 From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDc1rm601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SDc1rm601-d01673bcacfcc112c053d95971330335-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123 Params: sipp <sip:sipp1@192.168.1.60:5060> Params: sipp <sip:sipp2@192.168.1.60:5060> Edit: disp <sip:user@192.168.1.60:5060> Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140
Example 2 Manipulating the Request URI
For this manipulation rules, the Oracle Enterprise Communications Broker stores the URI parameter tgid in the Request URI. Then if the pattern rule matches, it adds a new header (x-customer-profile) with the a new header value tgid to the URI parameter in the request URI.
sip-manipulation name CustomerTgid header-rule name ruriRegex header-name request-uri action store comparison-type pattern-rule match-value msg-type request new-value methods INVITE element-rule name tgidParam parameter-name tgid type uri-param action store match-val-type any comparison-type pattern-rule match-value new-value header-rule name addCustomer header-name X-Customer-Profile action add comparison-type pattern-rule match-value $ruriRegex.$tgidParam msg-type request new-value $ruriRegex.$tgidParam.$0 methods INVITE header-rule name delTgid header-name request-uri action manipulate comparison-type pattern-rule match-value $ruriRegex.$tgidParam msg-type request new-value methods INVITE element-rule name tgidParam parameter-name tgid type uri-param action delete-element match-val-type any comparison-type case-sensitive match-value $ruriRegex.$tgidParam.$0 new-value
Request-Line: INVITE sip:service@192.168.200.60:5060 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK0g6plv3088h03acgh6c1.1 From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDc1rg601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SDc1rg601-f125d8b0ec7985c378b04cab9f91cc09-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Goodbye: Remove Me Custom: This is my custom header Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123 Params: sipp <sip:sipp1@192.168.1.60:5060> Params: sipp <sip:sipp2@192.168.1.60:5060> Edit: disp <sip:user@192.168.1.60:5060> Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140 X-Customer-Profile: 123
Example 3 Manipulating a Header
For this manipulation rule, the Oracle Enterprise Communications Brokerstores the pattern matches for the Custom header, and replaces the value of the Custom header with a combination of the stored matches and new content.
sip-manipulation name modCustomHdr header-rule name customSearch header-name Custom action store comparison-type pattern-rule match-value (This is my )(.+)( header) msg-type request new-value methods INVITE header-rule name customMod header-name Custom action manipulate comparison-type pattern-rule match-value $customSearch msg-type request new-value methods INVITE element-rule name hdrVal parameter-name hdrVal type header-value action replace match-val-type any comparison-type case-sensitive match-value new-value $customSearch.$1+edited+$customSearch.$3
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK20q2s820boghbacgs6o0.1 From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDe1ra601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SDe1ra601-4bb668e7ec9eeb92c783c78fd5b26586-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Goodbye: Remove Me Custom: This is my edited header Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123 Params: sipp <sip:sipp1@192.168.1.60:5060> Params: sipp <sip:sipp2@192.168.1.60:5060> Edit: disp <sip:user@192.168.1.60:5060> Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140
Example 4 Storing and Using URI Parameters
For this manipulation rule, the Oracle Enterprise Communications Broker stores the value of the URI parameter tag from the From header. It also creates a new header FromTag with the header value from the stored information resulting from the first rule.
sip-manipulation name storeElemParam header-rule name Frohmr header-name From action store comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name elementRule parameter-name tag type uri-param action store match-val-type any comparison-type case-sensitive match-value new-value header-rule name newHeader header-name FromTag action add comparison-type pattern-rule match-value $FromHR.$elementRule msg-type any new-value $FromHR.$elementRule.$0 methods
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK4oda2e2050ih7acgh6c1.1 From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDf1re601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SDf1re601-f85059e74e1b443499587dd2dee504c2-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Goodbye: Remove Me Custom: This is my custom header Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123 Params: sipp <sip:sipp1@192.168.1.60:5060> Params: sipp <sip:sipp2@192.168.1.60:5060> Edit: disp <sip:user@192.168.1.60:5060> Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140 FromTag: 1
Example 5 Manipulating Display Names
For this manipulation rule, the Oracle Enterprise Communications Broker sores the display name from the Display header. It replaces the two middle characters of the original display name with a new string. Then is also replaces the From header’s display name with “abc 123” if it matches sipp.
sip-manipulation name modDisplayParam header-rule name storeDisplay header-name Display action store comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name displayName parameter-name display type uri-display action store match-val-type any comparison-type pattern-rule match-value (s)(ip)(p ) new-value header-rule name modDisplay header-name Display action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name modRule parameter-name display type uri-display action replace match-val-type any comparison-type pattern-rule match-value $storeDisplay.$displayName new-value $storeDisplay.$displayName.$1+lur+$storeDisplay.$displayName.$3 header-rule name modFrom header-name From action manipulate comparison-type pattern-rule match-value msg-type request new-value methods INVITE element-rule name fromDisplay parameter-name type uri-display action replace match-val-type any comparison-type pattern-rule match-value sipp new-value "\"abc 123\" "
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK681kot109gp04acgs6o0.1 From: "abc 123" <sip:sipp@192.168.1.60:5060>;tag=SD79ra601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SD79ra601-a487f1259e2370d3dbb558c742d3f8c4-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Goodbye: Remove Me Custom: This is my custom header Display: slurp <sip:user@192.168.1.60:5060;up=abc>;hp=123 Params: sipp <sip:sipp1@192.168.1.60:5060> Params: sipp <sip:sipp2@192.168.1.60:5060> Edit: disp <sip:user@192.168.1.60:5060> Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140
Example 6 Manipulating Element Parameters
For this more complex manipulation rule, the Oracle Enterprise Communications Broker:
- From the Display header, stores the display name, user name, URI parameter up, and header parameter hp
- Adds the header parameter display to the Params header, with the stored value of the display name from the first step
- Add the URI parameter user to the Params header, with the stored value of the display name from the first step
- If the URI parameter match succeeds in the first step, replaces the URI parameter up with the Display header with the value def
- If the header parameter match succeeds in the first step, deletes the header parameter hp from the Display header
sip-manipulation name elemParams header-rule name StoreDisplay header-name Display action store comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name displayName parameter-name type uri-display action store match-val-type any comparison-type pattern-rule match-value new-value element-rule name userName parameter-name user type uri-user action store match-val-type any comparison-type pattern-rule match-value new-value element-rule name uriParam parameter-name up type uri-param action store match-val-type any comparison-type pattern-rule match-value new-value element-rule name headerParam parameter-name hp type header-param action store match-val-type any comparison-type pattern-rule match-value new-value header-rule name EditParams header-name Params action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name addHeaderParam parameter-name display type header-param action add match-val-type any comparison-type case-sensitive match-value new-value $StoreDisplay.$displayName.$0 element-rule name addUriParam parameter-name user type uri-param action add match-val-type any comparison-type case-sensitive match-value new-value $StoreDisplay.$userName.$0 header-rule name EditDisplay header-name Display action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name replaceUriParam parameter-name up type uri-param action replace match-val-type any comparison-type pattern-rule match-value $StoreDisplay.$uriParam new-value def element-rule name delHeaderParam parameter-name hp type header-param action delete-element match-val-type any comparison-type pattern-rule match-value $StoreDisplay.$headerParam new-value
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK7okvei0028jgdacgh6c1.1 From: sipp <sip:sipp@192.168.1.60:5060>;tag=SD89rm601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SD89rm601-b5b746cef19d0154cb1f342cb04ec3cb-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Goodbye: Remove Me Custom: This is my custom header Display: sipp <sip:user@192.168.1.60:5060;up=def> Params: sipp <sip:sipp1@192.168.1.60:5060;user=user>;display=sipp Params: sipp <sip:sipp2@192.168.1.60:5060;user=user>;display=sipp Edit: disp <sip:user@192.168.1.60:5060> Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140
Example 7 Accessing Data from Multiple Headers of the Same Type
For this manipulation rule, the Oracle Enterprise Communications Broker stores the user name from the Params header. It then adds the URI parameter c1 with the value stored from the first Params header. Finally, it adds the URI parameter c2 with the value stored from the second Params header.
sip-manipulation name Params header-rule name storeParams header-name Params action store comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name storeUserName parameter-name user type uri-user action store match-val-type any comparison-type case-sensitive match-value new-value header-rule name modEdit header-name Edit action manipulate comparison-type pattern-rule match-value msg-type request new-value methods INVITE element-rule name addParam1 parameter-name c1 type uri-param action add match-val-type any comparison-type case-sensitive match-value new-value $storeParams[0].$storeUserName.$0 element-rule name addParam2 parameter-name c2 type uri-param action add match-val-type any comparison-type case-sensitive match-value new-value $storeParams[1].$storeUserName.$0
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK9g855p30cos08acgs6o0.1 From: sipp <sip:sipp@192.168.1.60:5060>;tag=SD99ri601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SD99ri601-6f5691f6461356f607b0737e4039caec-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Goodbye: Remove Me Custom: This is my custom header Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123 Params: sipp <sip:sipp1@192.168.1.60:5060> Params: sipp <sip:sipp2@192.168.1.60:5060> Edit: disp <sip:user@192.168.1.60:5060;c1=sipp1;c2=sipp2> Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140
Example 8 Using Header Rule Special Characters
For this manipulation rule, the Oracle Enterprise Communications Broker:
- Stores the header value of the Params header with the given pattern rule, and stores both the user name of the Params header and the URI parameter abc
- Adds the URI parameter lpu with the value stored from the previous Params header
- If any of the Params headers match the pattern rule defined in the first step, adds the URI parameter apu with the value aup
- If all of the Params headers match the pattern rule defined in the first step, adds the URI parameter apu with the value apu
- If the first Params headers does not match the pattern rule for storing the URI parameter defined in the first step, adds the URI parameter not with the value 123
- If the first Params headers matches the pattern rule for storing the URI parameter defined in the first step, adds the URI parameter yes with the value 456
sip-manipulation name specialChar header-rule name searchParams header-name Params action store comparison-type pattern-rule match-value .*sip:(.+)@.* msg-type request new-value methods INVITE element-rule name userName parameter-name type uri-user action store match-val-type any comparison-type case-sensitive match-value new-value element-rule name emptyUriParam parameter-name abc type uri-param action store match-val-type any comparison-type pattern-rule match-value new-value header-rule name addUserLast header-name Edit action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name lastParamUser parameter-name lpu type uri-param action add match-val-type any comparison-type case-sensitive match-value new-value $searchParams[^].$userName.$0 element-rule name anyParamUser parameter-name apu type uri-param action add match-val-type any comparison-type pattern-rule match-value $searchParams[~] new-value aup element-rule name allParamUser parameter-name apu type header-param action add match-val-type any comparison-type pattern-rule match-value $searchParams[*] new-value apu element-rule name notParamYes parameter-name not type uri-param action add match-val-type any comparison-type pattern-rule match-value !$searchParams.$emptyUriParam new-value 123 element-rule name notParamNo parameter-name yes type uri-param action add match-val-type any comparison-type pattern-rule match-value $searchParams.$emptyUriParam new-value 456
Request-Line: INVITE sip:service@192.168.200.60:5060;tgid=123 SIP/2.0 Message Header Via: SIP/2.0/UDP 192.168.200.61:5060;branch=z9hG4bK681m9t30e0qh6akgj2s1.1 From: sipp <sip:sipp@192.168.1.60:5060>;tag=SDchrc601-1 To: sut <sip:service@192.168.1.61:5060> Call-ID: SDchrc601-fcf5660a56e2131fd27f12fcbd169fe8-06a3gu0 CSeq: 1 INVITE Contact: <sip:sipp@192.168.200.61:5060;transport=udp> Goodbye: Remove Me Custom: This is my custom header Display: sipp <sip:user@192.168.1.60:5060;up=abc>;hp=123 Params: sipp <sip:sipp1@192.168.1.60:5060> Params: sipp <sip:sipp2@192.168.1.60:5060> Edit: disp <sip:user@192.168.1.60:5060;lpu=sipp2;apu=aup;not=123>;apu=apu Max-Forwards: 69 Subject: Performance Test Content-Type: application/sdp Content-Length: 140
Example 9 Status-Line Manipulation
This section shows an HMR configuration set up for status-line manipulation.
Given that the object of this example is to drop the 183 Session Progress response when it does not have SDP, your SIP manipulation configuration needs to:
- Search for the 183 Session Progress response
- Determine if the identified 183 Session Progress responses contain SDP; the Oracle Enterprise Communications Broker searches the 183 Session Progress responses where the content length is zero
- If the 183 Session Progress response does not contain SDP, change its status code to 699
- Drop all 699 responses
sip-manipulation name manip description header-rule name IsContentLength0 header-name Content-Length action store comparison-type pattern-rule match-value 0 msg-type reply new-value methods header-rule name is183 header-name @status-line action store comparison-type pattern-rule match-value msg-type reply new-value methods element-rule name is183Code parameter-name type status-code action store match-val-type any comparison-type pattern-rule match-value 183 new-value header-rule name change183 header-name @status-line action manipulate comparison-type case-sensitive match-value msg-type reply new-value methods element-rule name make199 parameter-name type status-code action replace match-val-type any comparison-type pattern-rule match-value $IsContentLength0 & $is183.$is183Code new-value 199 sip-interface options dropResponse=699
Example 10 Use of SIP HMR Sets
The following example shows the configuration for SIP HMR with one SIP manipulation configuration loading another SIP manipulation configuration. The goals of this configuration are to:
- Add a new header to an INVITE
- Store the user portion of the Request URI
- Remove all Route headers from the message only if the Request URI is from a specific user
sip-manipulation name deleteRoute description delete all Route Headers header-rule name deleteRoute header-name Route action delete comparison-type case-sensitive match-value msg-type request new-value methods INVITE sip-manipulation name addAndDelete description Add a New header and delete Route headers header-rule name addHeader header-name New action add comparison-type case-sensitive match-value msg-type request new-value "Some Value" methods INVITE header-rule name storeRURI header-name request-uri action store comparison-type pattern-rule match-value msg-type request new-value methods INVITE element-rule name storeUser parameter-name type uri-user action store match-val-type any comparison-type pattern-rule match-value 305.* new-value header-rule name deleteHeader header-name request-uri action sip-manip comparison-type Boolean match-value $storeRURI.$storeUser msg-type request new-value deleteRoute methods INVITE
Example 11 Use of Remote and Local Port Information
The following example shows the configuration for remote and local port information. The goals of this configuration are to:
- Add LOCAL_PORT as a header parameter to the From header
- Add REMOTE_PORT as a header parameter to the From header
sip-manipulation name addOrigIp description header-rule name addIpParam header-name From action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name addIpParam parameter-name newParam type header-param action add match-val-type any comparison-type case-sensitive match-value new-value $LOCAL_IP element-rule name addLocalPort parameter-name lport type header-param action add match-val-type any comparison-type case-sensitive match-value new-value $LOCAL_PORT element-rule name addRemotePort parameter-name rport type header-param action add match-val-type any comparison-type case-sensitive match-value new-value $REMOTE_PORT
Example 12 Response Status Processing
sip-manipulation name manip description header-rule name IsContentLength0 header-name Content-Length action store comparison-type pattern-rule match-value 0 msg-type reply new-value methods header-rule name is183 header-name @status-line action store comparison-type pattern-rule match-value msg-type reply new-value methods element-rule name is183Code parameter-name type status-code action store match-val-type any comparison-type pattern-rule match-value 183 new-value header-rule name change183 header-name @status-line action manipulate comparison-type case-sensitive match-value msg-type reply new-value methods element-rule name make699 parameter-name type status-code action replace match-val-type any comparison-type pattern-rule match-value $IsContentLength0 & $is183.$is183Code new-value 699 sip-interface options dropResponse=699
The following four configuration examples are based on the this sample SIP INVITE:
INVITE sip:service@192.168.1.61:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.60:5060;branch=z9hG4bK-1-0 From: sipp <sip:sipp@192.168.1.60:5060>;tag=1 To: sut <sip:service@192.168.1.61:5060> Call-ID: 1-15554@192.168.1.60 CSeq: 1 INVITE Contact: <sip:sipp@192.168.1.60:5060;user=phone> Max-Forwards: 70 Content-Type: multipart/mixed;boundary=boundary Content-Length: 466 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=audio 12345 RTP/AVP 18 a=rtpmap:8 G729/8000/1 a=fmtp:18 annexb=no a=sendrecv a=ptime:20 a=maxptime:200 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=video 12345 RTP/AVP 34 a=rtpmap:34 H263a/90000 a=ptime:30 --boundary--
Example 13 Remove a Line from SDP
In this example, the SIP manipulation is configured to remove all p-time attributes from the SDP.
sip-manipulation name removePtimeFromBody description removes ptime attribute from all bodies header-rule name CTypeManp header-name Content-Type action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name remPtime parameter-name application/sdp type mime action find-replace-all match-val-type any comparison-type case-sensitive match-value a=ptime:[0-9]{1,2}(\n|\r\n) new-value
The result of manipulating the original SIP INVITE (shown above) with the configured SIP manipulation is:
INVITE sip:service@192.168.1.61:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.60:5060;branch=z9hG4bK-1-0 From: sipp <sip:sipp@192.168.1.60:5060>;tag=1 To: sut <sip:service@192.168.1.61:5060> Call-ID: 1-15554@192.168.1.60 CSeq: 1 INVITE Contact: <sip:sipp@192.168.1.60:5060;user=phone> Max-Forwards: 70 Content-Type: multipart/mixed;boundary=boundary Content-Length: 466 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=audio 12345 RTP/AVP 18 a=rtpmap:18 G729/8000/1 a=fmtp:18 annexb=no a=sendrecv a=maxptime:200 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=video 12345 RTP/AVP 34 a=rtpmap:34 H263a/90000 --boundary-
Example 14 Back Reference Syntax
In this sample of back-reference syntax use, the goal is to change the To user. The SIP manipulation would be configured like the following:
sip-manipulation name changeToUser description change user in the To header header-rule name ChangeHeader header-name To action manipulate comparison-type case-sensitive match-value msg-type request new-value methods INVITE element-rule name replaceValue parameter-name type header-value action replace match-val-type any comparison-type pattern-rule match-value (.+)(service)(.+) new-value $1+Bob+$3
INVITE sip:service@192.168.1.61:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.60:5060;branch=z9hG4bK-1-0 From: sipp <sip:sipp@192.168.1.60:5060>;tag=1 To: sut <sip:Bob@192.168.1.61:5060> Call-ID: 1-15554@192.168.1.60 CSeq: 1 INVITE Contact: <sip:sipp@192.168.1.60:5060;user=phone> Max-Forwards: 70 Content-Type: multipart/mixed;boundary=boundary Content-Length: 466 … … …
Example 15 Change and Remove Lines from SDP
In this sample of changing and removing lines from the SDP, the goal is to convert the G.729 codec to G.729a. The SIP manipulation would be configured like the following:
sip-manipulation name std2prop-codec-name description rule to translate standard to proprietary codec name header-rule name CTypeManp header-name Content-Type action manipulate comparison-type case-sensitive match-value msg-type any new-value methods element-rule name g729-annexb-no-std2prop parameter-name application/sdp type mime action find-replace-all match-val-type any comparison-type case-sensitive match-value a=rtpmap:[0-9]{1,3}(G729/8000/1\r\na=fmtp:[0-9]{1,3} annexb=no)[[:1:]] new-value G729a/8000/1
INVITE sip:service@192.168.1.61:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.60:5060;branch=z9hG4bK-1-0 From: sipp <sip:sipp@192.168.1.60:5060>;tag=1 To: sut <sip:service@192.168.1.61:5060> Call-ID: 1-15554@192.168.1.60 CSeq: 1 INVITE Contact: <sip:sipp@192.168.1.60:5060;user=phone> Max-Forwards: 70 Content-Type: multipart/mixed;boundary=boundary Content-Length: 466 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=audio 12345 RTP/AVP 8 a=rtpmap:18 G729a/8000/1 a=sendrecv a=maxptime:200 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=video 12345 RTP/AVP 34 a=rtpmap:34 H263a/90000 --boundary-
Example 16 Change and Add New Lines to the SDP
In this sample of changing and adding lines from the SDP, the goal is to convert non-standard codec H.263a to H.263. The SIP manipulation would be configured like the following:
sip-manipulation name prop2std-codec-name description rule to translate proprietary to standard codec name header-rule name CodecManp header-name Content-Type action manipulate comparison-type case-sensitive match-value msg-type any new-value methods element-rule name H263a-prop2std parameter-name application/sdp type mime action find-replace-all match-val-type any comparison-type case-sensitive match-value a=rtpmap:([0-9]{1,3}) H263a/.*\r\n new-value a=rtpmap:+$1+" H263/90000"+$CRLF+a=fmtp:+$1+" QCIF=4"+$CRLF
INVITE sip:service@192.168.1.61:5060 SIP/2.0 Via: SIP/2.0/UDP 192.168.1.60:5060;branch=z9hG4bK-1-0 From: sipp <sip:sipp@192.168.1.60:5060>;tag=1 To: sut <sip:service@192.168.1.61:5060> Call-ID: 1-15554@192.168.1.60 CSeq: 1 INVITE Contact: <sip:sipp@192.168.1.60:5060;user=phone> Max-Forwards: 70 Content-Type: multipart/mixed;boundary=boundary Content-Length: 466 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=audio 12345 RTP/AVP 8 a=rtpmap:18 G729/8000/1 a=fmtp:18 annexb=no a=sendrecv a=maxptime:200 --boundary Content-Type: application/sdp v=0 o=user1 53655765 2353687637 IN IP4 192.168.1.60 s=- c=IN IP4 192.168.1.60 t=0 0 m=video 12345 RTP/AVP 34 a=rtpmap:34 H263/90000 a=fmtp:34 QCIF=4 --boundary-
