SNMP Support
The Oracle Enterprise Communications Broker provides SNMP support for the Rejected Messages data, so you can access this information externally. The new MIB objects are:
apSysRejectedMessages OBJECT-TYPE SYNTAX Counter32 MAX-ACCESS read-only STATUS current DESCRIPTION "Number of messages rejected by the SD due to matching criteria." ::= { apSysMgmtMIBGeneralObjects 18 } apSysMgmtRejectedMesagesThresholdExeededTrap NOTIFICATION-TYPE OBJECTS { apSysRejectedMessages } STATUS current DESCRIPTION " The trap will be generated when the number of rejected messages exceed the configured threshold within the configured window." ::= { apSystemManagementMonitors 57 } apSysMgmtRejectedMessagesGroup OBJECT-GROUP OBJECTS { apSysRejectedMessages } STATUS current DESCRIPTION "Objects to track the number of messages rejected by the SD." ::= { apSystemManagementGroups 18 } apSysMgmtRejectedMessagesNotificationsGroup NOTIFICATION-GROUP NOTIFICATIONS { apSysMgmtRejectedMesagesThresholdExeededTrap } STATUS current DESCRIPTION "Traps used for notification of rejected messages" ::= { apSystemManagementNotificationsGroups 26 } apSmgmtRejectedMessagesCap AGENT-CAPABILITIES PRODUCT-RELEASE "Acme Packet SD" STATUS current DESCRIPTION "Acme Packet Agent Capability for enterprise system management MIB." SUPPORTS APSYSMGMT-MIB INCLUDES { apSysMgmtRejectedMessagesGroup, apSysMgmtRejectedMessagesNotificationsGroup } ::= { apSmgmtMibCapabilities 37 }
