Introduction
This section provides a sample and format of each type of exported file from the Web-based GUI. Sample information in these files are provided as a reference for your convenience.
Exported file examples include:
- Session Summary exported file (text format)
- Session Details exported file (text format)
- Ladder Diagram exported file (HTML format)
Oracle recommends you open an exported text file using an application that provides advanced text formatting to make it easier to read.
