Configure a User Entry
To build a user database, you configure individual entries for users. Each entry defines the name or dialing pattern, dialing context, agent, and policy for a user. You can optionally add a description and tags to create and filter reports for users. A user can represent an account in your dialing network, such as an extension, a subscriber, or a phone number.
- Configure one or more agents.
- Configure one or more policies.
- Plan any tags that you want to use to create and filter reports for users.
In the
following procedure you can add multiple policies and tags to this user record.
Repeat the procedure for each user that you want to manually add to the user
database.
